Status
Not open for further replies.
1 - 1 of 1 Posts
I was a little too quick on the trigger and purchased an MRC44. It looks like a fine unit, but the problem is it doesn't have pre-amp outs. I can't return it, so I was wondering if anyone had ever heard of the following and what their thoughts were on it:
Russound ADP-1 Speaker to Line-Level Adapter
This line-level signal can then be fed to a high-power amplifier for applications requiring greater power.
RMS Continuous: 250 Watts/Ch.
Peak Power: 500 Watts/Ch.
Attenuation: -30 dB
Input Connector Wire Size: Up to 12-Gauge wire.
Is it worth it to throw more money at this? Or should I just ebay the thing? I will be feeding one of the zones into a Niles SI-1230 Amplifier.
1 - 1 of 1 Posts
Status
