Status
Not open for further replies.
1 - 6 of 6 Posts
I have company over and just booted up the old Z1 ... When it got to the end of the 30 second countdown it froze on 00 and just stayed there ... I could see the movie going around the edges of the countdown square but I couldn't get the countdown square to go away ... The Z1 will not respond to any of its inputs - it won't shutdown or anything ...
What do I do? I'm afraid if I do a hard shutdown while the bulb is still on it will fry the bulb ...
Has anyone ever heard of this before?
Does anyone have ANY advice for me?
Discussion Starter · #4 ·
Thanks for the advice, guys!
I ended up doing the hard shut down. She's been off for an hour or two now, so I'm going to turn the power back on and hopefully I won't be frozen any more ...
Discussion Starter · #6 ·
As far as I can tell, my Z1 has suffered no damage as well, pcaulfie. But then again, if it shortened the life of the bulb, I wouldn't notice it right away.
1 - 6 of 6 Posts
Status
