1 - 14 of 14 Posts
will getting better wires help with Audio from HD DVDs currently I have Z-5500s with the stock wires, Would i get better sound if i upgraded the wiring,
ps getting an onkyo 705 reciever for trueHD so would that help for that aswell (until i buy nicer speakers)?
pps Wiring is all under 50 ft
You can go into the receiver menu and increase the gain on each channel as well, giving more input to the power amp section. I did this on my 605, and where I used to have the master volume on 70, I get the same amount now at the 50-55 setting.
Discussion Starter · #6 ·
Originally Posted by Lonely Surfer /forum/post/12853108
You can go into the receiver menu and increase the gain on each channel as well, giving more input to the power amp section. I did this on my 605, and it where I used to have the master volume on 70, I get the same amount now at the 50-55 setting.
don't quite have the 705 yet.
If you have a good line on the 705, I'd say go ahead and get it. But I'd start saving money to upgrade your speakers. A new AVR will only go so far. In order to hear True HD, and other HD audio, you'll want new speakers also.
My 2 Cents
I have the Logitech Z-680s, which are Z-5500's older and bigger brother, and I can tell you that once you're ready to move up, move the Z-5500's to the den or whatever and build an entirely new setup from scratch. Don't bother with upgrading the speaker wires above the included 18-gauge wiring, it's just not worth it, you won't hear any difference. The Z-680s and Z-5500s are great multimedia computer speakers and I love my Z-680s to death, but a centerpiece for a full-blown home theater, they are not.
Discussion Starter · #9 ·
so upgrade the speakers for the Logitech 5500 reciever, or upgrade the Reciever for the 5500 speakers, what would get better results first? both are temp solutions, I will get both a new Reciever and new speakers but not at the same time.
Another question about wire gauge would it hurt my speakers if i went to say 12 or 10 gauge?
It won't hurt, but it won't help.
If you use the Z-5500 sats with a real receiver, if you turn the volume up too much you risk blowing them out. They are not designed for a high power source.
If you use the Z-5500 amp with real speakers, it might work ok, but the amp is half of the sound so I don't know how much improvement you would hear. If the speakers are big enough I doubt the Z-5500 amp will be able to drive them to acceptable volumes without distortion.
Discussion Starter · #11 ·
Total FTC power: 505 watts RMS
Sub-woofer: 188 watts RMS (into 8 ohms, @ 100Hz, @ 10% THD)
Satellites:
Left/Right: 62 watts RMS x 2 (into 8 ohms, @ 1khz, @ 10% THD)
Center: 69 watts RMS (into 8 ohms, @ 1kHz, @ 10% THD)
Rear Left & Right: 62 watts RMS x 2 (into 8 ohms, @ 1kHz, @ 10% THD)
Total Peak power: 1010 watts
Maximum SPL: >115 dB
Frequency response: 33 Hz — 20 kHz
Amplifier: Ultra-linear, high-capacity analog
Signal to noise ratio: >93.5 dB, typical 100
the onkyo is 100 watts per channel and my current are 62 L,R,SL,SR and 69 Centre. is this too much of a difference?
Discussion Starter · #13 ·
is .1 THD better? I just got a system genesis g 6030 for almost free thats .1 THD with 200 watts per sat. will that be better for the Onkyo reciever?
just checked the new speakers out, they are bad apparently. a scam or something.
How do you do this? what is the benefit? I mean, do you lose or gain dynamics?
1 - 14 of 14 Posts
