41 - 46 of 46 Posts
Discussion Starter #42
Here's the main thread, can't say I came up with the idea. I didn't want plain acoustic panels- I wanted movie posters. Basically I wanted portrait style movie posters without text. There's a moviepostersdb website out there, and blurayforum has a bunch as well.
Here's my post on construction.
Basically a 3" frame. But jointed. Braced from behind to provide rigidity. Stuffed with Roxul Safe n Sound (only ridgid type insulation I could find. According to a gearslutz review it has the same properties as 2" of 703 with an air gap. Much cheaper than the hundreds of dollars in shipping fees I would have had to pay for 703). Wrapped once with black jersey meaterial stretched super tight to keep from sagging, keep fibers in check, provide a black background for the posters. Then put the posters on top. The one thing I would do differently is either add 1/2" to my poster prints or measure the posters before building the frames. Most of mine were 1/4 to 1/2 inches too small and had to be stretched a little more than I wanted to stretch them. Glad I had the black behind them, otherwise the frames would show.
Been subscribed from your start and love how everything has turned out. Our rooms are similar in size so I was very interested. Whenever I get around to finally starting on my build I will be referencing your build frequently. Your color scheme is exactly what I was wanting and will definitely be using the movie poster idea for room treatments. Nice Job!
Discussion Starter #45
Thanks. The walls are Sherwin Williams 'peppercorn' latex flat, and the trim is 'greenblack', oil based satin. Ceiling and front wall are greenblack latex flat.
Discussion Starter #46 (Edited)
Interval update: Upgraded to a JVC projector and decided to try and maximize the room a bit more. Changing out the carpet is t an option- yet. We matched the rest of the basement- in retrospect I would have gone darker from the outset.
But- I painted the ceiling with BM ultra flat ceiling, black color. The SW was always dark but not quite black. I underestimated how much light was reflecting back on the screen. I also painted the front wall with the same paint. After a movie last night I’m also going to black out the vertical soffit surfaces.
I also stole the idea for a simple ‘stage’ up front by using a few sheets of plywood, painted black and wrapped in velvet. I didn’t want a formal built up stage. I wanted the screen as low as possible. This helps the front of the room disappear. The football helmets will be relocated to the back wall.
The JVC was already a huge improvement over my Epson but this pushed it over the top.
$80 paint. $75 plywood. $40 velvet. Significant improvement in picture quality.
EDIT: First pic is rotated but that’s my ceiling halfway through painting.
41 - 46 of 46 Posts
