As the title says, I'm going to build a home theater sub using an Alpine Type R 15" sub. I bought this speaker before I started reading the forums and learned about the whole DIY world that existed for home theater. I already own the beast though, and it is one, so I would really like to use it, even if it is not perfect. It is a DVC sub and I am using a pro amp to power it. It is an American DJ amp. Don't laugh too much, it was free. It is rated for 1050W into 4ohms mono.
I have gone through and downloaded WinISD and designed a box. I just would like some experienced input to make sure that I am on the right track. Here are the T/S parameters. (Sorry they are not in order for WinISD, I am going off of the manual.)
Alpine Type R SWR-1541D
Impedance 4 ohms per coil (will probably be wired series for the amps sake)
Power Handling 500W RMS/ 1500W Peak
Frequency Response 24-1,000 Hz.
Sensitivity 89db
Re 4 ohms per coil
Le 6.2mH/1.86mH
Fs 24Hz
Vas 98L
Qms 9.68
Qes .5
Qts .48
X max 14.5mm
X peak 29mm
Mechanical Excursion (P-P) 68mm
Hag 15mm
Hvc 44mm
Sd 754.77cm2
Magnet weight 129.6oz
Voice Coil Diameter 65mm
Those are all of the parameters that I have. I am looking at a 6 cu. foot internal volume max. I might could fudge a little to the larger size, but would like to keep around 6. I was looking at a 18hz tune since it seems to plot nicely, but I'm not sure how much I should be worried about that. If I go for a 15hz tune, I see a -6db down point of 14hz. Which I have read is pretty good. Then there is the whole port noise issue to worry about. Truth be told, I'm just over analyzing this, I think.
Thank you guys in advance for sharing your knowledge with me.
Sensitivity 89db
Re 4 ohms per coil
Le 6.2mH/1.86mH
Fs 24Hz
Vas 98L
Qms 9.68
Qes .5
Qts .48
X max 14.5mm
X peak 29mm
Hag 15mm
Hvc 44mm
Sd 754.77cm2
