Hi-Power and projector mounted to low ceiling?
384 Views 2 Replies 2 Participants Last post by  jcase
I'm considering the purchase of the hi-power screen to mate to my Sharp 12k.
From the diagrams below, can anybody tell me how much gain I would end up with in this setup? I may end up swapping the front and back row to put 2 seats in the front and 3 in the rear.
If you can't tell me the gain, please give me some feedback if you think this would work with good results?
http://www.caseserve.com/ht/images/After_Side_View.jpg
http://www.caseserve.com/ht/images/After_Top_View.jpg
Status
Not open for further replies.
1 - 3 of 3 Posts
That's very similar to the angles/distances I had with my HS10. I had about 2x gain in the front row, and something in the area of 2.5 on the riser. It should work very well.
Thanks Kevin
1 - 3 of 3 Posts
Status
