I am finishing up the home theater and trying to figure out the best way to mount my projector screen. On the wall is a LCD Samsung, that with mount, sticks out about 5". The ceiling is vaulted and sloped so the projector screen has to be wall mounted. The screen is a Da-Lite Model B, 106" 16x9 with wall mount and hanging brackets. Because I have to extend the screen away from the wall by about 6 inches to clear the TV, I am thinking about building some kind of wood blocking behind as a spacer and a casing around the screen roll using 1x4 and crown molding to match the room. Before I dive into the project, just wanted to see if you guys have come across this and what kind of solutions have worked well for you.
Eric
Eric
