Anyone out there using this card? I looks very impressive. I would imagine this in a HTPC taking all of the signals switched by my Denon 5800 and upconverting them to 1080i. Has anyone used it?
Originally posted by seanbrwn427 Ok, Seems there are a few people ouot there using this card. Now... could I persuade any of you to share a little about the other video cards you have picked to put in the system with it and what projectors your using. I am in BUY mode and need to hear some good ideas before I spend my MONEY!!!! Thanks! |
Originally posted by seanbrwn427 Ok, I have a Sony HD100 HDTV Direct TV reviever. Is this equivalent to the 5000 unit you mentioned? -----> No, VERY different animal. -What I am really interested in is the ability to scale the input signals from the various sources to an optimal setting for my front projector. ----> I use a RPTV HDTV so I can not help you there but here are the scaling choices in the Hipix: Joe |
Originally posted by JB72 I got the impression that you can't route your DD 5.1 output to your soundcard with the HiPix. Is this true? Also, which card, (HiPix vs. AccessDTV) has the better PQ? Given the same source of course. Geese I really wish there was a cheap generic reciever card that could use the Radeon 8500 or Geforce 3 for HDTV and scaling. TIA |
You can route your DD 5.1 output to your soundcard's digital input on both accessDTV and Hipix. The only thing you have to do is have a sound card that will support this. |
Originally posted by mkanet I see a lot of people buying a cheap and used Hipix card to use as a secondary card. |
Currently, the Hipix has better PQ and overall brighter and more vivid picture than the accessDTV. |
You will never be able to do that with an accessDTV card. |
