Status
Not open for further replies.
1 - 4 of 4 Posts
Coming accross this website ( http://www.hdtvauthority.com/hipix_1.htm ) I noticed they sell a 26 pin connector to connect the hipix directly to the video card.
Here's what I dug up on the site about it:
When using a PC Monitor for display, the user can even view digital
(ATSC) signals as a Picture within a Picture (PIP) on his PC monitor.
This feature also allows the window size and aspect ratio settings of the
Picture within a Picture ( PIP)* window that will appear on the PC monitor.
*VGA cards with an on board 26 pin connector (typically 'ATI' models) require
an Optional Flat Cable for connection to the HiPix DTV-200 Card in order to
enable the 'PIP' feature.
All 4 aspect ratios are available, each in several sizes, (within the
basic '16:9' and '4:3') - as per options in the Control Panel Setup Screen.
The PIP feature is also usable when the 'Auto Program' is enabled (in
'TUNER' mode) where the HiPix DTV-200 is used to Scan for, and
Compile a List of all available ATSC (Digital) or NTSC (Analog) TV
Channels - as well as when in 'LINE IN', 'S-VIDEO' or 'FILE', mode
Has anyone tried this?
Did you order it yet? (I hope not...)
-The newer HiPix software releases make this cable (a "VIP cable") unnecessary, since the same ability is now in the HiPix program itself (called VOP).
-Even if your video board has the matching connector (a VIP connector), newer drivers may not support it. Any Nvidia drivers newer than the original Windows XP release do not work, for example.
1 - 4 of 4 Posts
Status
