Status
Not open for further replies.
1 - 6 of 6 Posts
Banned
Sorry that this question is so basic, but I can't find any threads which list the answer to my questions.
Which video cards will allow me to connect it to the HiPix card so that I can view my desktop on my HDTV using only the HiPix's VGA/RGB connector for all HTPC video on my HDTV?
Thanks for your help!
Banned
Discussion Starter · #2 ·
Boy, how dumb can I be...
I think I just found the answer to my own question. All I need do is connect the included loop back cable from my video card to the HiPix card and whalaa! Instant desktop and HiPix in one.
Sorry for placing this question so quickly without researching it more beforehand!
merc,
Does your HDTV have VGA/RGB input?
Kei Clark
Digital Connection
Banned
Discussion Starter · #4 ·
Kei: Yes it does. I've been using the HiPix card attached this way for about a month now, but have been running a seperate S-video connection from my old video card to the HDTV for seeing my desktop. It is a real pain switching from the S-video input (to use the HiPix Application) to the VGA/RGB input(to actually see the HDTV I just tuned to in the Hipix App). It would be nice to just keep it on the VGA input and have a desktop overlay or even a window for that matter. I have a Pioneer 64HD5 and will am buying a new video card tomorrow... any suggestions for that?
Is the loop back cable all I need to do this?
Banned
Basically any VGA card can "passthrough" a desktop
signal through the HiPix to your display. The problem
is that many displays will only display 1080i
or 540p type signals - so - (unless your VGA card
comes with one of those modes) you may need to try
the free "Powerstrip" software to set custom VGA modes
that will work on your display.
The general preference around here for VGA cards
is an ATI Radeon series (best for DVD playback) or
NVidia GeForce series (best for 3D games) card.
1 - 6 of 6 Posts
Status
