Status
Not open for further replies.
1 - 1 of 1 Posts
I am having a rather strange problem. Two days ago I notice on startup I was only getting one DTV channel (previous strongest). Previously I was recieving 5 in DC area and 4 Baltimore channels (using an RF switch to change antenna inputs).
Am running HiPix beta 3 RC1 - it was working with all channels. I uninstalled and reinstalled including using the HiPix cleaner utiity. I disconnected the rf switch and ran with only one coax directly to card from antenna with rotor. Got 2 stations (only) that way with careful pointing; with a third available with bad strength in a different direction.
HiPix autodetect will sometimes note some of the previous channels but not add due to apparent low signal; and I can manully add them but ss is around 5 at best for the previous good channels.
It seems to me like an rf pre-amp or something like that has gone bad in the card. Any ideas before I investigate whether or not I can get repaired under warrentee??
1 - 1 of 1 Posts
Status
