Status
Not open for further replies.
1 - 1 of 1 Posts
My hipix digital tuner will not work after then computer has been off for awhile. It's really irritating because the fastest, most efficient cure is a knock on the case of the computer, and I'd rather not do that. The analog tuner works all the time and the file playback works all the time.
I also might have to reboot several times before the hipix will lock onto certain channels and stay locked whether I move around or not.
Is there any help please?
Also, I have begun to see the need to change the recording size to 2 seconds. How do I change the registry? Also, tips on mass renaming of .ts files would be nice so I can use Xmuxer easily.
Darius
1 - 1 of 1 Posts
Status
