Status
Not open for further replies.
1 - 6 of 6 Posts
I have the HiPix card and it does a great job of recording HDTV programming. It hasn't failed me yet when set up using the Titan Guide. On playback the video looks great and the audio sounds great, but the longer you watch, the more the video and audio get out of sync.
Is anyone else having this problem?
Does anyone have any suggestions for fixing it? It gets quite distracting after about a half hour of viewing.
Larry
San Francisco
Discussion Starter · #3 ·
I'm using the latest version and drivers.
It only does this when playing back files. I don't have the problem when watching OTA reception.
Larry
Mine doesn't have this problem. It did it once, but a reboot fixed it and it never occured again.
Do you have the latest Midwinter version, not Telemann version?
Make sure you have DMA turned on for all of your drives.
Try turning off the VOP preview.
Discussion Starter · #6 ·
Thanks for the suggestions, Balazer.
I am using AVS version 3.5.2 with the version 3 drivers for Windows Xp.
I don't use VOP preview, but I have no idea whether or not DMA is turned on for my one 200 GB drive. Where would I find that info?
You can contact me direct, if you wish.
Larry
1 - 6 of 6 Posts
Status
