The HiPix card does support this, although I havent heard of many people using this feature. You have to have a VGA card with a compatible VIP adapter (see the user manual on the HiPix site for more details).
I have not observed any nor have I heard any complaints from anyone else.
I may have missed this feature, but I don't believe it does that. And I'm not sure anyone knows what will be in the next SW rev. Keep in mind though that the HiPix 2.3 software can only record DTV (ATSC) not NTSC.
Yes, its the same question. Sorry, don't know about nVidia cards, but you can check their website.
No one has heard of any. I've owned the HiPix card for about two months and really like it.
-MM
1. Does the software allow you to view tv in a rescalable window? If so, are there many buttons and such that cannot be removed? I like browsing the web and doing other stuff with tv rescaled to a small window in the corner of the screen, and not being able to make the controls/buttons disappear hinders my navigational abilities... |
2. Are there any signal degradation issues from using the loop-back cable? |
3. Is there an option to pause the live feed, as with the TiVo and accessDTV? If not, does anybody know if this is a feature that will be integrated into 2.4? |
4. I don't understand what the VIP connection is for... does this relate to #1? Is the Picture-In-Picture what I refer to as rescalable window? How would this feature be useful? Do any nvidia-based cards have VIP connectors? |
5. Are there any other cards that I don't know about, or that will come out shortly, which may be better than the Hipix? |
-MM
