HK 435 Problem?
620 Views 4 Replies 2 Participants Last post by  phishdisc
Purchased a refurbed 435 through HK direct.
Finally got it all set up.
I have the mulit-room speakers going to a speaker distribution panel which splits it to three rooms.
I am using the surround speakers for the multi-room setup until I can get an amp.
When I have the multi-room turned on, after a little bit the AVR cycles the power.
Anyone experience this problem? Is this sometihng the firmware update will fix or should I contact HK ?
Status
Not open for further replies.
1 - 5 of 5 Posts
anyone ever experience the HK receivers to turn itself off after a few minutes when multi-room is turned on ?
Sounds like you are using one of the Monster or Niles multi-speaker switcher...
If yes..
Those units have a very low impedance and can likely trigger the AVR's protection circuit..
A possible way to test is to disconnect the multi-speaker switcher from the AVR..
Now turn ON Multi-Room..
1. Does the AVR stay ON?
If Yes...
Then the switcher is putting a very low impedance load on the AVR..
Causing a shutdown..
Also you can easily check if the AVR is outputting properly by connecting 1 pair of speakers to the Multi-Room speaker out on the AVR..
2. Does the AVR still turn OFF?
If Yes..
Then a problem inside the AVR..
See less See more
Thanks for your input.
Here is how I have it set up:
multi-room speaker connections to speaker distrubtion panel
from there each of the 3 set of speakers to volumne matching impedence control then to the in-ceiling speakers
Right now I am using the surround speakers for the multi out, until the amp gets in.
I will do the tests you suggested. thanks!
See less See more
an update:
I tested the multi room function with just my front speakers. Everything stayed on.
Now, when I get an amp to power the multi-room speakers, will this fix the problem?
1 - 5 of 5 Posts
Status
