1 - 9 of 9 Posts
the samsung HL67A750 67" LED is the best rear projector right?
are there any other TVs out there that are better or are there going to be any coming out anytime soon that are better?
Does it really last 60,000 hours? no bulb replacement?
yes the sammy HL67A750 is the best LED DLP nobody else makes LED DLP's
no theres nothing better out there unless u want to spend $5000 + for a pioneer kuro
yes it really lasts 60000 more or less no bulb replacement needed because it has an LED engine ,no bulbs and no color wheels
better get one while they are still available
The Mitsubishi Laser DLP may be better but it cost over $6000 (65").
Get It while it's Hot
The 73735/736 Mitsubishi sets are as good or better than the Samsung HL67A750 and can be found for under $2200.00. They are bulb based DLPs and PQ is excellent.
thats what u think when in fact they are not even close
+1
I considered exchanging the Sammy (because mine had an issue) for a Mits but after looking at the Mits again there is NO WAY I would switch. In fact, I would have kept the Sammy, with the issue it had, before switching to the Mits. I exchanged it for another 67" and couldn't be happier. I have no "brand loyalty". If I don't like it, I don't keep it.
There are no absolutes here. PQ is purely subjective to most people. The HL67A750 is a fine TV as many have stated but there are other options that don't involve sinking 5 grand plus in a plasma or laservue. Compare these DLPs whenever possible and pick what you think renders the best image. That's what I did.
Absolutely, then come back for all the info you could ever need about your new Sammy!
1 - 9 of 9 Posts
