1 - 2 of 2 Posts
Hi, I have a HLN5065W and after about an hour the screen starts flashing white. If I turn off the set for 20 mins or so, I can then turn it back on and watch it for another hour.
I'm not getting any errors and replaced the bulb...same issue. Do you think a fan is going out? I found this link on how to replace the fan but I'm not getting any error messages so I'm not sure if that is the problem.
http://www.jangro.com/a/2006/09/29/s...replace-fan-2/
1 - 2 of 2 Posts
