Status
Not open for further replies.
1 - 3 of 3 Posts
I just got my 507 and went into the SM and it shows 302?
Is this a major release? Did I see someone with 304?
What are the differences between the 2.x and the 3.x versions?
I was looking forward to adjusting based on you guys experience, now I wonder if I have to wait for someone with all the equipment and knowledge to calibrate one. (I know it should be done set by set but...)
Already had to adjust the yxis it was set to 11 and showed a white line on the top so I bumped up to 16 to make it go away.
Side question.
How do you guys tell what the resolution the source feed is?
Thanks everyone!
Michael
P.S. My wife and I both are the lucky segment that sees the rainbows.
I try to slow my eye movement down.
Coyote Waits
There is not much you can do about it if it's enough to bother you. Some people stop noticing them -- others never stop being bothered.
Hope you have a good return option if you prove to be in the later group.
No one has reported what firmware version 302 does. The previous version released was 214. Samsung jumps numbers all the time. The latest version that I've read about is 306.
1 - 3 of 3 Posts
Status
