HLN567 Problem...
179 Views 3 Replies 3 Participants Last post by  davidyyc
I've had this TV for over a year, and I just had something pop up. It has lines in areas where there is a shading graduation. Kind of hard to describe, but it looks like a topographical map with gradient lines at times, instead of a smooth transition of the tone. It is especially noticeable on some faces, and also on something like a wall. And it just started out of the blue in the last couple of days.
Anyone know what this is, or what the problem might be?
Thanks so much.
Status
Not open for further replies.
1 - 4 of 4 Posts
Sounds like it's time for a service call. Did you buy an extended warranty?
You might want to try re-booting your STB. Does this happen on all inputs?
Yeah, it should still be under warranty. And I should unplug the sat receiver just in case, but it does happen on DVD's as well (different inputs, of course).
Just kind of a weird thing. Probably something going funny in some kind of processing chip or something, I guess.
Thanks for the input.
1 - 4 of 4 Posts
Status
