Status
Not open for further replies.
1 - 10 of 10 Posts
· Registered
Ok, so I splurge for the Monster DVI400 Cable to connect my brand new 61 inch and my brand new Samsung 931 DVD player.
Guess what? The cable has a flared rubber side to it and the plug on the TV is recessed. IT WON'T FIT!!!
Can anyone recommend a cable that can be purchased at a CC, Tweeter or Best Buy?
BB had one in the computer section (Belkin) but I guess I fell for the Monster Marketing pitch as I didn't buy it. Will that one work?
Thanks gang!
· Registered
I had the same issue last night with the monster cable. It does fit, it's just a very tight fit. If you push a little bit you can get it in there. It was a little scary but it worked.
· Registered
Discussion Starter · #7 ·
I went to a local Microcenter and picked up a dvi computer cable for $30. I feel soooo foolish for falling for the Monster Cable Marketing scam. The Monster cable is going back to Best Buy this weekend and I'm pocketing the $70 difference....
by the way, have i mentioned I love this TV?
· Registered
Did you guys order a dual link or single link from pacificcable? I'm thinking of ordering a 2m or 3m DVI-D cable but was wondering if there were problems/incompatablities with either one. Your thoughts?
Also, is shipping rates reasonable with this company?
· Registered
When it comes to DVI, Moster's claims are even more ridiculous than with their other cables. Unless defective, pretty much all DVI cables work the same at lengths under 5m or so.
If you want to buy local, buy whatever is cheap.
If you are willing to go online, you can likely get comething with express delivery for less than local. Pacifcable gets rave reviews. I got mine off eBay for $7 shipped. Works great.
As for the single/dual thing, single is all you need. However, since dual link is often only $1-2 more, you might want to get dual incase you need dual sometime in the future.
· Registered
Here's another vote for Pacificcable. Quick shipping, great quality, and good prices. No, they didn't gouge for shipping either...
I bought a dual link cable, but single link will work fine for you... Your application (present generation DVD player to present generation TV) doesn't require the bandwidth of a dual link cable...
Marc
Marc
1 - 10 of 10 Posts
Status
