I have found a really great thread on color wheel replacement, however, the tv was slightly different from mine and apparently, according to this post... mine's much simpler. Just looking to see if anyone knows of a step by step replacement guide with pics on the hlp4663wx/xaa unit.
Is it really that easy? Not sure which cables he's referring to and would really like a few pics to guide me. Already spent $130 on a bulb thinking that was the reason. Now I gotta order a color wheel
Also, who might have the best deal on a color wheel?
OK, I had a chance to closely look at the directions on that link you posted. My TV set is slightly different and apparently even easier than that one. My TV has a slide out tray that totally disconnects and removes from the TV enclosure. This tray houses the color wheel, lamp assembly and projector. Two cables to disconnect and it slides right out all together.
I can then take that tray and bring it to a table where I can work on it easily. We'll see.
