1 - 3 of 3 Posts
Hi for some days a have a strange sound when the tv is from one or more.
th sound is like a static pop noise...at cold the sound is normal but when is hot i have this strange sound,Any idea what about this sound?
One or more what?
What's connected to the TV for audio?
Are you using an A/V receiver?
Are you using an external STB?
Are you using OTA, cable or satellite receiver?
Are you using red/white audio cables, optical, coax.... etc.
"POP Noise"... can be attributed to many problems including household appliances. So, more detail would be helpful.
Discussion Starter · #3 ·
Tank you for your fast responce!!!,i have make a try Without any device connected on the tv and the problem persist but when a close the tv the sound comeback after 1 hour,i have made a check to the rear fan (for overheat)
and the fan work but at very very low speed and the bulb is new,the ballast seem ok,pluged the tv alone in the plug...nothing the problem persist.
excuse my english im french.
1 - 3 of 3 Posts
