Panasonic HMC40 AVCHD direct to Blu Ray questions?
OK; Windows XP platform, Panasonic HMC40 AVCHD camcorder. No current software. Want to be able to provide Blu Ray discs that will play on any new BD player.
For this application no editing will be needed or desired. Quick, simple turnaround is the goal. Should be able to accomplish this with no trans-coding correct?
Can someone suggest a simple workflow, software, and burner requirements?
Also, the ability to do AVCHD on DVD simply without editing or trans-coding would be nice for shorter projects, but do realize that they may not necessarily play in all BD players.
Thanks for the help.
ETA someone told me that I wouldn't actually need ANY software beyond Nero of such BD burning software... Just pull the files from the card, rearrange the folder structure, possibly change some file extensions, and burn to BD with Nero or similar... Anyone shed some light on this?
