1 - 2 of 2 Posts
Im planning on running speaker wire through a wall, was wondering what would be good to hide the small hole? Would you suggest a rubber hole plug. I will be getting the wire on the other side of the wall, however this is an attached garage which isnt insulated as well as the rest of the house and believe there will be a draft problem.
I was suggested this by monoprice. But I think that it will be too big of a hole. My direct tv installer used a rubber plug or bushing to cover the hole and allow the cable to go through.
http://www.monoprice.com/products/pr...t=1#largeimage
1 - 2 of 2 Posts
