Home Audio Build 7.1 suggestions
232 Views 1 Reply 2 Participants Last post by  RayGuy
2
AVS crew
Looking for some guidance direction on 7.1 System. Entire Room is pre-wired at locations shown on attachment.
Also Room dimensions are shown on attachment.
Also if suggestion about location to source as local is limited to best buy. Frys is 3hrs ea way
I can be way off on the budget. I have looked at definitive audio and sounded great. Although considering how to reduce cost.
Ideal is $2500 total budget although doesn't seem realistic.
7.1 Receiver Recommendation:
Target Budget Flexible $600+ship/tax
Where to source?
Ceiling Speakers:
Target Budget Flexible $150ea+ship/tax
Where to source?
Ceiling Speaker Center:
Target Budget Flexible $250ea+ship/tax
Where to source?
Floor Standing Fronts:
Where to source?
Sub:
Target Budget Flexible $300+ship/tax
Where to source?
HDMI Cable 25':
Target Budget Flexible $50ea+ship/tax
Where to source?
See less See more
1 - 2 of 2 Posts
TV over fireplace? If so, then get yourself a Mantlemount (or similar) and attach the center channel to the bottom of the mount/TV. This layout solves many problems. First, it moves the TV down to a reasonable level, so you do not have neck strain from constantly looking up. Second, the center channel speaker will be more in line (laterally) with the front L&R (having the center in the ceiling, with the L&R at ear level will be problematic, as the sound will fluctuate vertically as it pans from left to right). Lastly, you want your front three to be as similar as possible, and floorstanding vs in-ceiling are about as different as it gets in sound character.
1 - 2 of 2 Posts
