I don't actually intend to use the Vinyl Roller shade I purchased from Home Depot yesterday for $30, but my Epson 6500UB should arrive tomorrow and I was searching for ideas on what to use for a temporary screen surface. I can't paint a wall because A) wife would kill me and B) I have no such suitable wall. I'm going to use "queen size white flannel sheet" and the "vinyl roller" for experiments.
Update Jan 7th, 2009
I got my 6500UB today, and out of desperation, tried to use the 6mm white room darkening shade I purchased last week. Here are my initial thoughts:
1. Hotspotting? Certainly none that I can see, other than the waves, #2
2. Waves? omg yes. After much gnashing of teeth, I finally just pulled up the screen from the base of the fireplace, and put some books on the top of the mantle to hold it up there. Maybe I just need to troll around for techniques for tightening cheap retractables
3. There are some lines in the screen, like little folds, about every 6-8 inches, that I can only really see on the right hand side of the screen. They're the most noticeable in brighter scenes, and only when I'm looking for them. But pretty annoying when I do see them.
I'd rate the lines as the most annoying thing, perhaps enough to prevent me from wanting to continue to use it temporarily. I'll see what my wife says. Heh, she's the decisive one. She's also told me she wants the screen to fit on the mantle (70" wide) and a gray screen to help combat ambient light because she wants lights on. So my search has gotten easier, unless I can can convince her bigger would be better ... But that seems unlikely
So my question perhaps has moved to interesting ways to mount a retractable on a fireplace mantle, but I'm going to give it a few more days
End Update, and actual mini review
In the end, I'm probably going to go with a commercial retractable, but I've been pouring over Tiddler's threads on various ideas for painting cheap retractables (not as cheap as mine, but cheaper than Da-Lite Design Countour), and I think my big question at the moment is still more of a DIY question anyway.
Here are some room pics to describe my problem. This is the view directly from the couch. The room is 12 ft wide, so from couch to front of fireplace is about 11.5 ft, a little shorter if I have to push the screen in front of the bookcase on the right. The ceiling is 7'11. The top of the mantle is about 63" high.
(The white balance is a little off, the mantle is white, not offwhite.)
I could call this thread, "No, Really! Who says you need a dedicated home theater room?!" My WAF challenge is to make sure the room doesn't look like an office training room with a proj, and not an altar to the God of Consumerism and Media. That's why I'm taking the Projector Challenge--hopefully I can hide everything when we aren't watching. This is another view from the couch, to the existing 27" Sony CRT and my 3 L/R/C Mirage OmniSat Micros.
You can see the missing spot from where our cable box used to be and my sad little attempt at an HDTV antenna (insufficient gain of another kind, in this case).
I'm shooting for a screen between 70" (the width of the widest part of the mantle) and 85" wide, in other words, between SMTPE minimum and THX recommended viewing angles. I'm just going to go 1.78 ratio because it seems easier. With the projector mounted most likely on the back wall near the ceiling, my throw will be about 11.5 ft too. At these screen sizes, with Art @ projectorreview's lumen numbers , I get pretty decent numbers for ft lamberts just using (screen area in ft) / lumens; 21 at the lowest for calibrated Theater Black at 85" wide, and 107 at 70" wide in Dynamic. Yes, my ceiling is white, but with such a pitifully (picayune, indeed) small screen, I hope light has to far to go to the ceiling. White carpeting, too, but we can put a dark blanket on the floor if it's too bad.
ANYWAY, I've been struggling (enjoyably, mostly) with the challenge of how to mount a retractable screen reasonably invisibly, and where to put my three L/R/C speakers. I was thinking ceiling mount for a long time, with a ~ 40" screen, I figured I needed about 30" of drop, which was well within what SeymourAV would do if I needed a "cheap" retractable AT screen. I was starting to think about building a box on the ceiling to hold some lights, so it would look like a box to help illuminate pictures on the mantle, but now I'm leaning towards a "mantle mount."
It's hard searching for "fireplace mount" here because that's usually someone putting a flat panel above their fireplace. I'm trying to decide if I could mount a good looking retractable case directly to the top of the mantle (which limits me to 70" wide), or if it would be "easy" enough to build some sort of "mantle extension" that would go on top of the existing mantle, and perhaps be a little wider to accommodate a wider screen. The top section is just over 4" high, but I probably don't want to cover the decorative part of the mantle.
Any thoughts from the masters of DIY? If my 6500UB does come tomorrow (I never got a tracking number, so who knows), I'll post some followups with my results from "white flannel sheet / blanket" or perhaps even take the plunge with the DesignerView(TM) Vinyl Roller Shader. If movies only look good at night in the end, that will be OK with me
Thanks so much to everyone for their hard work and information sharing, and happy new year! I'll check back tomorrow to see if any of this made sense, too
