I would like to do something more than the typical home distribution panel. I don't want to have coax cables simply all going directly to a single splitter or amp and doing nothing more, because as times change you can use the cable for so many different applications, like HDMI over CAT6, or HDMI over coax.
Also, I don't understand why there is usually a single unbroken coax line from satellite dishes to the receiver, because it is tacky having to drill holes in floors to have a 150ft long wire poke straight up through carpet or a hardwood floor to the sat receiver.
I want a termination/patch panel like you see in professionally wired networks, where the wires come in to the distribution room/closet, and they all go to a row of termination connectors. If you want to use a connector you run a patch cable from the termination to the splitter/amp/switch/media-converter.
Outdoor satellite dish connections and so forth would also come to the termination panel. If a satellite signal needs to go to a particular room, run 0.5 meter coax patch from the satellite input port to the room port, without having to hack holes in the floor for the satellite cable.
It's odd but it appears the idea of a termination/patch panel is totally foreign to most home wiring systems.
It looks like I am going to have to blow a pile of money going with professional termination components:
HDMI termination panel, up to 16 ports:
1.75" X 19" Blank Panel w/ 16 Universal DB9/HD15/HDMI Cutouts, Black - $53
http://www.l-com.com/item.aspx?id=30846
HDMI Panel Mount Adapter, Female to Female, $10 each .. 16 is $160
http://www.l-com.com/item.aspx?id=9016
Coaxial termination panel, 16 ports:
1.75" x 19" Panel (Black), 16 F Coupler -- $80
http://www.l-com.com/item.aspx?id=853
CAT6 termination panel, up to 16 ports:
Category 6 Keystone Jack, 110/RJ45 (8x8), EIA568A/B -- $8 .. 16 is $128
http://www.l-com.com/item.aspx?id=7804
1.75" Blank Panel Accepts 16 Keystone Couplers -- $ 30
http://www.l-com.com/item.aspx?id=9357
6U swing-out rackmount panel
6" Pivoting Panel Wall Mount Cabinet, 6 Rack Spaces -- $103
http://www.l-com.com/item.aspx?id=4962
1U panel blanks for labeling connectors
1.75" Panel, Blank Steel -- $21
http://www.l-com.com/item.aspx?id=8799
Total cost for 16 HDMI, 16 CAT6, 16 coax + rack + 3 1U blanks for labeling ... $617
....but I would like to find a less expensive option if possible.
Apparently there aren't any other options.
