Hello,
I've just built my Blu-Ray/HD-DVD HTPC and would like to set up my system to get high definition audio, such as Dolby TrueHD, out of it. My sound card is the Auzentech Prelude and my receiver is the Onkyo 605.
- I understand that playback software such as PowerDVD will not not downgrade high definition sound when using the analogue connectors.
- Ironically, optical cables will not deliver trueHD sound because of limited bandwidth. As for HDMI 1.3 support, it doesn't yet exist for these sound cards. So I need to avoid the digital connectors.
Therefore, from what I understand (and correct me if these assumptions are incorrect), the analogue connectors will allow me to get TrueHD from the sound card. So I need to get the appropriate "analogue" cables such as the Creative Home Theater Cable to connect my sound card to my receiver.
The problem is that I'm not US based and cannot find this cable anywhere. I'm also a bit concerned: If this is the solution to getting true high definition sound, then why isn't it a bit easier to find? (And it's rather cheap and doesn't look like such a high quality cable...) Regardless, does anyone know where I can get this in the UK or Europe or do I have to import it from the US?
