Status
Not open for further replies.
1 - 6 of 6 Posts
Someone who knows more than I do, please help!
I own a decent TV and a computer that will be placed nearby it. I am looking to build a home theatre around the TV, so I've got a decision. I don't want to spend much money on this. Should I go ahead and buy a home theatre in a box, or is there a decently cheap way for me to build just as good a system, using my computer?
So option 1 - spend $300-500 on a home theatre in a box.
Option 2 - buy speakers, a decent sound card, and whatever else i'd need to hook my TV and video game systems through my computer to pump sound out of those speakers? i've got a decent computer with a dvd drive, but i would have to invest in a decent sound card i know.
Which option is best, and can anybody give me direction on what to buy? I don't plan on ever blasting the volume on this system, so I don't need serious watts, but I do want Dolby Digital, DTS, and pro logic 2 (which some of my games would take advantage of)
I would go with a separate system. PCs don't display well on TVs, and if you buy equivalent speakers and all you will not save a lot of cash, and you will not be able to use your PC while watching TV
I disagree about the computers not displaying well on TV's. Depending on the TV DVI input can look fantastic. If you don't have access to DVI using a VGA to Component transcoder like the ones made by Key Digital and Audio Authority can produce very nice results. With a transcoder and a decent video card you can have 1080i DVD playback and desktop which look very nice for general use, Web surfing and movie watching.
Go to the Home Theater Computer section and read and decide.
By decent tv, do you mean high definition? If so, then a htpc IS an excellent way to go!
A good soundcard and a set of Klipsch speakers (or Logitech Z series) can fill a small room with very good sound at an attractive price.
No idea if ProLogic2 is on the pc, yet.
Discussion Starter · #6 ·
No I don't mean decent TV meaning an HDTV. I have more knowledge than the average joe about electronics, but don't have the cash yet to spend as much as I'd like to on it. So considering about a $400 ceiling, any home theatres-in-a-box stand tall above the others?
1 - 6 of 6 Posts
Status
