1 - 1 of 1 Posts
I'm currently assembling a 9.1 system using a new Denon 4311 AVR. together with a 7 channel power amp. Which way should I go with these problems?
1/ I want to use front highs as well as normal front surrounds should they be wired together off one output or separated out the power amp?
2/ The center will be directly out the power amp?
3/ The side surrounds from the power amp?
4/ The rears from the Denon directly?
System is used for music, Blu ray and TV. TV use is the highest and we get dolby sound delivered via free to air here.
1 - 1 of 1 Posts
