1 - 5 of 5 Posts
I need help eliminating 225/month cable bill by using Hulu plus, etc via PS4 and a digital HDTV antenna through my Sony DA5200ES. Can anyone advise how to hook antenna up? I have a Panasonic 65" monitor (no TV tuner there!)
PS Comcast is KILLING me!  Thank you!
Yes.  They make them as a DVR and as just a Tuner.  Really depends on how you want to do this.  If you want to use a desktop computer as a HTPC (Home Theater PC), to allow you to stream online shows and record OTA (Over The Air) Programming, there are a couple of tuner card options.  If you just want something that sits alongside the Blu-Ray player, there are also DVR options that also have online Streaming capabilities.
Really depends on how much you wish to budget.
Discussion Starter · #5 ·
Thanks again, Jack. Now I'm starting to get it. Won't use the laptop, but a DVR option might be good for us. That is one of the things I will be turning in to Comcast when I sort this out!  We have PS4 with streaming options, but I could get a DVR (right now I forgot name of popular one) and it would work as tuner/recorder, yes?
Thank you for being nice to me with my rank amateur questions!
1 - 5 of 5 Posts
