Status
Not open for further replies.
1 - 3 of 3 Posts
Overview: I have a projector (Sanyo Z1) and an Xbox that I am trying to run through my reciever (Yamaha HTR-5280) using component connections. I know that in order to run two component inputs through the receiver, I need to use the Component Out on the receiver.
Problem: When I hook up the DVD to the component inputs on receiver labeled DVD, the receiver does not recognize the signal under that input. Instead, I have to switch to VCR1. It appears to me that my receiver is faulty. This would be fine with me, but the VCR1 input does not have a slot for a Dobly Digital audio connection (optical or coaxial). Obviously, I need a this kind of connection for DVDs. I am running the Xbox components through the input labeled DTV, which DOES have a corresponding Dobly Digital audio input.
The basic problem is that I have two component inputs but only one of them has a corresponding Dolby Digital Audio input. Does anyone have any ideas? Is my receiver faulty? The component input on the back labeled DVD should correspond to the Dobly Digital Audio connection labeled DVD, but it doesn't.
Any help is appreciated.
Adam
1 - 3 of 3 Posts
Status
