Status
Not open for further replies.
1 - 6 of 6 Posts
Discussion Starter #1
Help!
I have a 50" panny 6uy and I am trying to get ota channels. I have a HTL-HD receiver and is hooked up to the panny via DVI. I purchased a Terk TV55 and tried to hook it up to the HTL-HD for ota channels. After scanning, I turned to the respective digital channels and got nothing but the dreaded "no signal" alert.
Am I hooking it up wrong? Terk TV55 to ant. in of receiver. Nothing to panny except for DVI connection with the receiver. The panny 6uy does not have an antenna hookup.
Banned
Your problem is the Terk TV55 antenna, its the most terrible antenna you could try! Return it immediately and get a real all-metal antenna like the Channel Master model 4221 or if you need indoor try a Zenith Silver Sensor. You may need to aim the antenna properly too and get it outside high enough.
Discussion Starter #4
Thanks for the info. So my hookup is ok then? I'll look into the channel master.
Originally posted by Mtb5
...So my hookup is ok then?...
Yes. The problem is very likely your TERK antenna, which may look "cool" but rarely works well.
1 - 6 of 6 Posts
Status
