I've had my 42" Panasonic TH-42PX50U for about 3 years now, and over the course of the last couple of months have noticed a clear brightness division running horizontally through the middle of the panel, with black levels noticeable lighter on the bottom half.
The issue is only really clear during darker scenes in movies, and even then only depending on the type of dark/black scene being shown. If there is no picture on the screen and it's just black, then the difference is quite stark. If the scenes have a lot of color though or are bright, you can't tell at all.
Is a plasma panel usually composed of two separate displays one on top of the other, and is the bottom one aging or fading faster than the top for some reason? Is this some kind of screen failure? Can I expect it to get worse?
