Status
Not open for further replies.
1 - 1 of 1 Posts
Hello All,
I recently purchased a Toshiba 50H82 projection television. This is my first projection TV so I'm not sure if what I am seeing is a common occurance or something out of the norm. At about the half-way point on the verical axis, I see a horizontal "hot spot"... a line approximately 1/2" thick with soft edges that stretches the entire width of the screen. This is most noticable on solid colored backgrounds; it tends to blend in well over "busy" images although it is still present.
Any ideas of what this might be and does it merit a call to the dealer for servicing?
-TomK
1 - 1 of 1 Posts
Status
