It seems that Max SPL is calculated using 8 ohms and not the actual resistance of the driver. As a result, the power limited SPL is too high. The problem is worse the lower the actual resistance of the driver.
Example:
On the main data page, I enter 500 watts and 2.8 ohms. The voltage is 37.42. Press calculate and the SPL shows about 122 db for the horn I have in front of me. Then go to Tools > Max SPL, and enter 500 watts and 15 mm. Press OK and Max SPL is showing power limited at 127 db at the same frequency.
Then go back to main data entry page and enter 500 watts into 8 ohms and get 63.25 volts. Press calculate and the SPL shows 127 db.
If others confirm this bug, I'll drop a note to McBean.
Example:
