http://funk.eu/hrc/
Found a pretty cool tool tonight. By running that program you can set a Harmony button to switch resolutions in WMC (or any program for that matter). I used Alt1 for 60hz and Alt2 for 24hz.
I've only played with it a bit so far but it has potential. Just 2 bugs I need to iron out:
-running it seems to have disabled my skip buttons. I will try some different shortcut combos
-you have to press your desired resolution hotkey twice. it will momentarily flip to the one you pressed, but then flip back. Pressing it a second time seems to make it stick. Same with switching back. Could this be an edid negotiating problem?
If I can solve for those two things out I think this will make a much better solution than an external player.
Any other users?
Any other users?
