Status
Not open for further replies.
1 - 5 of 5 Posts
Can't seem to get PBS-HD to come through.
Have tried on Analog, Cable, HRC and IRC in the HDTV Setup.
I can get it to show up in the guide (Under channel 80) but anytime I try to tune in, the signal strength fluctuates wildly between 0-60 ... I cannot get a lock. In fact I have never seen a picture, even a pixelated one.
All other Houston DTV comes in great ... I am using a Channel Master outdoor antenna that has been recommended here.
I have already tried the steps detailed here:
http://www.avsforum.com/avs-vb/showt...ht=houston+pbs
Any help would be appreciated ...
Apparently you've set ANALOG TYPE to Cable, which is required to tune to virtual channel 80.
Do you have a VHF antenna? PBS broadcasts on Channel 9. If you do, be sure it's aimed to the Southwest, toward Missouri City.
(I have a DISH 6000, very close to you (I'm in Atascocita), and I get it fine.)
Discussion Starter · #3 ·
VHF Antenna? I have a big Channel Master outdoor antenna
what is the model #?
Discussion Starter · #5 ·
Dunno ... Is there any easy way to tell without climbing on my roof
1 - 5 of 5 Posts
Status
