We have a place about about 20 minutes NW of Sealy. As the crow flies, it is approximately 60 miles from there to the Antenna Farm near Missouri City. Here is the link to the rabbit ears maps:
https://www.rabbitears.info/searchmap.php?request=result&study_id=17723
There really is no address so you can use 78933 as the zip code to find it on the map.
The antenna finders show that I'll need a medium range directional as the stations are all SE of my geographic location.
IMPORTANT: this antenna will be used to tune 2-3 TVs in a metal building/barn. I can mount it on the sheet metal covered patio near the roof line (approx. 10 ft) or if necessary, I can mount it higher up on the actual roof.
Is it worth trying to get other stations from Austin etc? I would be happy with quality and CONSISTENT reception from Houston, so I would like advice on a solution to do this once without too much regard to cost. Obviously, I don't want to spend money for no reason, but I will consider more expensive solutions if the quality and value is there. IOW, I don't want to spend money on components like amplifiers if they are just going to overdrive my signal and cause problems; but, I really don't know much about OTA or set top boxes that allow recording like TIVO.
If there are cool, RELIABLE gizmos that improve the OTA experience, I would appreciate any info on that to help me make a decision.
This signal will be used with a Vizio 75 in class TV. I assume you can hook up the coax antenna wire to an HDMI adapter input. Is that correct?
Thanks for your help in advance.
