I posted this in the screen section...but didn't know if it would be better here...
I've finally been able to get funds for my theater/family room, but we've decided to change where it's going. And due to this point, I'm now facing an issue on screen size.
Max I can get is 92" due to one a bulk head and a sidewall at 92", and the wife doesn't want it fixed to the wall.
Now my question is this, is 92" to big?
I can sit back at least 10-15 feet away. My ceilings are at 7 1/2 feet.
The projector will likely be the Optoma HD20. The projector itself can go back as far as 20 feet if need.
My biggest concern is the one sidewall that runs the right side for about 5-6 feet at this 92" point (image an L shape then another right cut). Will this cause to much light reflections? The walls are dark grey and I have total light control.
My fronts shouldn't be to much of an issue as they will be under the screen as at 92", I'd have enough space to do so.
Any help is truly grateful...been so happy to finally get to this point but don't want to make a mistake making it not enjoyable.
