Leon!
Three potential possibility;
-Since you mention it was during watching TV, it could have been the station you were watching/or your provider of this channel having some audio drop.
-Or, it is your new AVR (assuming it is a an AVR, since you are into the AVR/AVP section to post your question), having some issue, if so, return it while you can.
-The last possibility depend of what level of sound you were listening, did it happen during loud scenes (could also could be more distortion from a TV source, than a direct source like a BD, during those loud moment), or
-if playing very loud, the AVR could have put it-self into protection mode, shutting down for a few seconds, to protect it-self (meaning your were playing too loud), and would be normal.
If you were playing at moderate volume, monitor different stations, to see if the situation can be replicated over a short time, while the AVR can be return.
If it happen often, and never happen before, return the AVR, if not it could have been only the channel or your provider, at that time.
Those are the only things, I can think about
Ray
Ray
