1 - 4 of 4 Posts
how can i connect my sonyBDP-380 blu-ray player by hdmi cable(as well as my sky box which is already connected by hdmi) when i am not able on this tv,
(which has 3 hdmi inputs) to use 2 or more hdmi terminals at the same time.
jefferryp
Discussion Starter · #3 ·
Originally Posted by home5254 /forum/post/21389452
if your tv has 3 hdmi inputs plug each device then select the input u want to watch or use
thanks for your reply ,but although i have 3 inputs i must only use 2 for hdmi and one gets me tv and the other is for sky and to use my bluray i have to take my tv hdmi out & put my bluray hdmi in.i would like to avoid this constant replacement of leads every time i change from tv to bluray.
You say the TV has three HDMI inputs but you can only use two of them. Why is that?
You can get an HDMI switch from monoprice.com. I used a 3x1 switch for several years and recently went to a 5x1. They both worked flawlessly.
1 - 4 of 4 Posts
