Status
Not open for further replies.
1 - 5 of 5 Posts
I take the pragmatic approach on this one:
There are many front-firing subs that respected reviewers say sound great.
There are many down-firing subs that respected reviewers say sound great.
Therefore, the effect, if any, must not be significant to my sub buying decision. ;)
You can load a down-firing driver closer to a tri-corner space if you're so inclined.
Forward-firing drivers usually end up at least 2' from one wall when placed in a corner.
Downward drivers have to be specifically designed for this orientation, to prevent dynamic offset from occurring.
ie: the cone is naturally biased downward by gravity; it will also tend to move more easily in that direction, potentially causing an offset in the VC gap.
1 - 5 of 5 Posts
Status
