Problem:
I am using the October version of ffdshow for watching movies through Zoom Player. I have noticed that when watching media files through WMP10, mainly the WMV-HD trailers off that website, the files have different audio settings, because it is using the ffdshow audio filter for audio.
The audio options are in WMP10 -> Tools -> Options -> DVD -> Advanced. At home, this brings up the ffdshow audio filter program/dialog, while at work on this computer it looks like it's using WinDVD 6 for audio, as that brings up the WinDVD audio dialog.
So at home, some files require me to use AC3, and others need 16-, 24- and 32-bit integer checked instead.
However, if I try and install the August version of ffdshow for faster resizing algorithms, it is missing the AC3 audio option from the ffdshow audio filter/codec dialog, and I can't view these files.
Question:
Is there a way to specify which audio filter/codec WMP10 uses? Either through a graph, editing a file in the WMP directory, or installing something else after ffdshow to take over that slot?
Question:
