Status
Not open for further replies.
1 - 2 of 2 Posts
How do I clean dust blobs on a Proxima X350, ASK M3, A+K X10?
I opened the projector and removed the top cover. However, I have no idea how to get to the DMD panel. Is there something else I have to remove? Any help or link to pictures on how to clean these projectors would be appreciated.
//Rhubyrod
To clean dust on the X350 ... go to ...
http://www.proxima.com/support/contact.asp
... and locate a local service center. Have them do it. :D
Cleaning the panels on an LCD block are one thing ... but trying to navigate the guts of a DLP is a completely different animal.
Let alone the actual DMD chip ... I would avoid touching/cleaning the actual mirrors at all costs. Unless of course you do know what you are doing ... in which case no insult was intended.
In any case, these little 3 pound DLP's tend to be a nuisance to clean.
1 - 2 of 2 Posts
Status
