Status
Not open for further replies.
1 - 3 of 3 Posts
I have a Dish 500 (with two single LNB's), an oval dish (with dual LNB) and two switch 21's. Can I use this combination with my DTC100 to receive Direct TV HDTV? Is there a website that diagrams how to connect it?
Tony
Premium Member
I don't know what a switch 21 is, but you will need a 4x4 (or 4xANY) multiswitch so that any of the four LNB can be tuned to with your DTC-100. You will have to point one dish to the 101' bird (feeding into the "A" inputs on your multiswitch) and one to the 119' bird (feeding into the "B" inputs on your multiswitch). You will not be able to pick up the Sat C channels, which are DirecTV Para Todos, NASA and SHO-HD.
Mike
Premium Member
If you go to the wiring diagram link at 18inch.com, you will see a bunch of suggestions for mixing DirecTV and Dish equipment.
1 - 3 of 3 Posts
Status
