I'm wondering if I can get this answered without specifics.
I have a pretty normal rectangular room with a front projector system. I'm currently sitting about 13 ft away from the screen. My front three speakers are the same distance from the center of viewing position. I tried for a equilateral triangle between listening position and front speakers but didn't quite get it. I am however within the Dolby specs of 22 to 30 degrees I believe. My front speakers, forward facing ports are about 2 ft from the front wall and 1 1/2 ft from the side walls.
My question is regarding direction of the front speakers. Obviously I can go from forward facing or toe-in the speakers so they are facing the viewing position. I know that this changes the characteristics of the sound but what should I be listening for when I'm playing with the angle of the speakers, are there things I should avoid or things I should shoot for. I do have access to a spl meter, should I use that in my testing? Basically it all boils down to how do I set the toe-in for my front speakers?
Josh
Josh
