Question is 2-fold for Audyssey XT32 experts here. But a little background on my setup to understand my questions. My LCR channels consist of speakers with powered subs (built-in amps), that require an RCA signal from the prepro. Since I hate using Y-adapters, I plan to use the RCA outs of the prepro for my power amps feeding the passive part of those speakers. And then use the XLR outs of the prepro into an active XLR-to-RCA converter and feed the active subs of all 3 speakers.
So that leads me to question #1 . Will Audyssey XT32 process both the XLR and RCA LCR signals as one where both connections are used ? My guess is yes, since it will simply shoot out pink noise to determine if anything is connected to those channels, and will hopefully apply the same processing to both XLR and RCA outputs for each channel.
Now onto my 2nd question with background first. I am running 4 Clark Synthesis Gold shakers in my couches, driven by 2 pro audio amps (Carver). I have a pro XLR distribution unit that takes an XLR in and feeds 4 XLR outs to these amps. I do not want or need Audyssey processing on this signal, the shakers do not need to be room corrected.
So my 2nd question, if I am using an actual sub on the RCA out of the prepro, I intentionally leave the XLR disconnected to the shaker amps, run Audyssey so room correction is applied only to the sub on the RCA, then connect the XLR cable afterwards. Will that XLR out on the prepro be functional post XT32, with an unprocessed signal ??
I realize this is not your typical XT32 or prepro setup, but I need to wrap my head around how Audyssey will handle this.
Thanks guys !!
Neil
Thanks guys !!
Neil
