Originally Posted by thebard /forum/post/20849642
I'm sure others will chime in with a more detailed answer, but very basically: a white flash is sent to the screen in between the content, and the active glasses use this to sync the shutters.
Originally Posted by machavez00 /forum/post/20852842
I hope you are not going to use DirecTV with that setup. Unless something has changed, checkerboard is NOT supported by D* receivers.
Originally Posted by aoaoo0 /forum/post/20851996
Because the DLP imaging chip is so fast, it is able to project two images on the screen at one time to create the 3D image viewed through the active glasses.
Originally Posted by DenisG /forum/post/20852902
Front DLP projectors are not checkerboard.
Originally Posted by thebard /forum/post/20853033
This is not really correct. The L/R images are displayed in sequence, alternating L/R 120 times per second, in sync with the shutters on the glasses. It's very fast, but it's not "at one time". If the two views were displayed simultaneously with active glasses, it would ruin the 3d effect.
Because the DLP imaging chip is so fast, it is able to project two images on the screen at one time to create the 3D image viewed through the active glasses. But, in addition to the two images on the screen, the DLP chip also sends additional data to the glasses in-between each frame of video. This is how the projector communicates with the DLP link enabled active glasses. This ingenious transmission technique makes data emitters obsolete and eliminates the need to install and position emitters. This saves you time and money and makes setup of a 3D Ready DLP projector quick and easy.
Originally Posted by evnow /forum/post/20853269
Actually he is just quoting TI.
http://www.dlp.com/projector/dlp-inn.../dlp-link.aspx
Originally Posted by thebard /forum/post/20853278
May be so... but still not correct!
Shame on you, Texas Instruments...
Originally Posted by cakefoo /forum/post/20860668
Here's a video I shot at 600fps that shows what goes on:
The DLP Link flash is blue, probably because white is more complicated, taking 3 times as long to produce.
Originally Posted by nickels55 /forum/post/20869652
What color tint do you get on your set in 3D mode? On my Samsung it is hot red so my guess is the DLP flash is a different color on my set.
