This unit has no mounting holes or screws in the bottom, except one foot that screws for adjustability (and can easily be removed, so there's 1 hole) and one mystery screw that is directly under the lens area, undocumented. If this hole can be used, then that makes 2 holes at diagonally opposite corners, which would be fine for this little 3.3 lb unit.
All the manual says about ceiling mounting is: "don't do it yourself, have a professional do it, or you might drop it and break it." Very helpful. So how do the pros find out how to do it?
Has anyone figured this out?
Paul
Paul
